Всем доброго дня! Прихожу домой, а свет не включается... перезагрузил малинку через reboot - не помогло. Захожу на сервер - половина устройств пропала и находятся в категории удалённые устройства с незарегистрированным классом команд... В логе весёлые сообщения типа: Device 10 does not exist. NIF coming from a phantom? Есть какие-то идеи, как это возникло и как это починить? Спасибо!
UPD:
[2014-10-23 20:00:37.464] SendData Response with callback 0xc6 received: received by recipient
[2014-10-23 20:00:37.464] Job 0x13 (Schedule Change Report (schedule change mechanism disabled)): success
[2014-10-23 20:00:37.465] Removing job: Schedule Change Report (schedule change mechanism disabled)
[2014-10-23 20:00:37.465] Job 0x13 (MultiCmd, clock report, Schedule Change Report (schedule change mechanism disabled)): Delivered
[2014-10-23 20:00:37.465] SETDATA devices.14.data.lastPacketInfo.delivered = True
[2014-10-23 20:00:37.465] SETDATA devices.14.data.lastPacketInfo.packetLength = 15 (0x0000000f)
[2014-10-23 20:00:37.465] SETDATA devices.14.data.lastPacketInfo.deliveryTime = 158 (0x0000009e)
[2014-10-23 20:00:37.466] SETDATA devices.14.data.lastPacketInfo = **********
[2014-10-23 20:00:37.466] SendData Response with callback 0xc6 received: received by recipient
[2014-10-23 20:00:37.466] SETDATA devices.14.data.lastSend = 93880486 (0x059880a6)
[2014-10-23 20:00:37.466] Job 0x13 (MultiCmd, clock report, Schedule Change Report (schedule change mechanism disabled)): success
[2014-10-23 20:00:37.466] Removing job: MultiCmd, clock report, Schedule Change Report (schedule change mechanism disabled)
[2014-10-23 20:00:37.534] SENDING (cb 0xc7): ( 01 09 00 13 0E 02 84 08 05 C7 A7 )
[2014-10-23 20:00:37.545] RECEIVED ACK
[2014-10-23 20:00:37.555] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-10-23 20:00:37.556] SENT ACK
[2014-10-23 20:00:37.556] Delivered to Z-Wave stack
[2014-10-23 20:00:37.730] RECEIVED: ( 01 06 00 49 20 0F 00 9F )
[2014-10-23 20:00:37.730] SENT ACK
[2014-10-23 20:00:37.730] Node 15 was removed
[2014-10-23 20:00:38.053] Executing script: api("/v1/devices", { ...
[2014-10-23 20:00:38.078] Executing script: api("/v1/notifications", { ...
[2014-10-23 20:00:38.077] Adding job: Get routing table line
[2014-10-23 20:00:38.083] Adding job: Get routing table line
[2014-10-23 20:00:38.084] Adding job: Get routing table line
[2014-10-23 20:00:38.095] RECEIVED: ( 01 06 00 49 20 0E 00 9E )
[2014-10-23 20:00:38.095] SENT ACK
[2014-10-23 20:00:38.096] Node 14 was removed
[2014-10-23 20:00:38.098] Job 0x80 (Get routing table line): Cancelling job: Get routing table line
[2014-10-23 20:00:38.098] Removing job: Get routing table line
[2014-10-23 20:00:38.098] Job 0x80 (Get routing table line): removing duplicate
[2014-10-23 20:00:38.099] Job 0x80 (Get routing table line): removing duplicate
[2014-10-23 20:00:38.100] Job 0x80 (Get routing table line): removing duplicate
[2014-10-23 20:00:38.116] RECEIVED: ( 01 06 00 49 20 0E 00 9E )
[2014-10-23 20:00:38.116] SENT ACK
[2014-10-23 20:00:38.117] Node 14 was removed
[2014-10-23 20:00:38.127] RECEIVED: ( 01 06 00 49 20 0E 00 9E )
[2014-10-23 20:00:38.128] SENT ACK
[2014-10-23 20:00:38.128] Node 14 was removed
[2014-10-23 20:00:38.138] RECEIVED: ( 01 06 00 49 20 0E 00 9E )
[2014-10-23 20:00:38.139] SENT ACK
[2014-10-23 20:00:38.139] Node 14 was removed
[2014-10-23 20:00:38.150] RECEIVED: ( 01 06 00 49 20 0C 00 9C )
[2014-10-23 20:00:38.150] SENT ACK
[2014-10-23 20:00:38.150] Node 12 was removed
задан 23 Окт '14, 21:45
chorus12's gravatar image
chorus12
3611934
процент согласия: 16%
отредактирован 04 Дек '14, 02:53
PoltoS's gravatar image
PoltoS ♦♦
5731512
Лог после загрузки в студию! (можно в почту)
Скорее всего дохнет плата (замена по гарантии) или разовый сбой. Попробуйте полную перезагрузку по питанию (полностью отключите от питания на 10 секунд).
И бэкап сделайте!!!!
(24 Окт '14, 00:33) PoltoS ♦♦ PoltoS's gravatar image
Выше фрагмент лога. Как послать весь по почте? Как сделать бэкап - имеется ввиду вызвать ссылку ZWaveAPI/Backup ?
(22 Ноя '14, 15:07) chorus12 chorus12's gravatar image
Такая же проблема повторяется и у меня. Какая Вас версия прошивки ? Давайте искать решение проблемы вместе.
(24 Ноя '14, 23:20) Ostapich11 Ostapich11's gravatar image
Не подскажите пожалуйста как Вы лог посмотрели?)
(24 Ноя '14, 23:38) Ostapich11 Ostapich11's gravatar image
Добрый день! Версия прошивки - 1.7 Смотреть лог - зайти на малинку и дать команду: tail -n <число выводимых строк лога> -f /var/log/z-way-server.log Проблема, как мне сказали не из одного источника - медленно горит плата razberry - надо менять по гарантии. Вопрос к администрации форма - как это организовать?
(27 Ноя '14, 22:36) chorus12 chorus12's gravatar image
Отправить в магазин, где купили, и ждать назад замены.
(28 Ноя '14, 02:25) PoltoS ♦♦ PoltoS's gravatar image
Я покупал у Вас в ту пору, когда вы ещё торговали в розницу. Приходить в любое время в рабочие часы на Щепкина?
(30 Ноя '14, 20:39) chorus12 chorus12's gravatar image
Да, конечно. Желательно, но необязательно только предварительно позвонить.
(01 Дек '14, 09:32) Nils_Bohr Nils_Bohr's gravatar image
Хорошо, спасибо!
(02 Дек '14, 23:10) chorus12 chorus12's gravatar image
showing 5 of 9 show 4 more comments
Внимательно ещё раз посмотрел на Ваш лог (пришлось его переформатировать, а то он был нечитабелен).
Это не умирающая плата. Отнюдь... Такое видели только у одного клиента до этого. И он не смог воспроизвести. Хотя до сброса контроллера у него такое было постоянно. Скорее похоже на взбесившуюся прошивку. Другой версии нет, ибо проблем с ней не было до этого. Или же это помехи в эфире, которые кажутся чем-то нормальным чипу, но вряд ли. Мы это не смогли у себя воспроизвести никак.
Решение предлагается простое:
  • делаете бэкап (если поздно, то берёте старый)
  • делаете сброс к заводским настройкам
  • восстанавливаете из бэкапа с восстановлением структуры сети
Проблема, думаю, не повторится.
ссылка
отвечен 04 Дек '14, 02:57
PoltoS ♦♦
5731512
процент согласия: 27%
отредактирован 04 Дек '14, 02:58
Ваш ответ
toggle preview
Следить за этим вопросом
По почте:
По RSS:
Ответы
Ответы и комментарии
Основы размётки
  • *курсив* или _курсив_
  • **жирный** или __жирный__
×257
×163
Задан: 23 Окт '14, 21:45
Просмотров: 3,146 раз
Отредактирован: 04 Дек '14, 02:58
powered by OSQA
