Помогите! Где ошибка?
-- NOTICE TO CHANGE DEVICES ID's:
%% properties
362 value
66 value
%% globals
-- BATHROOM SCENE FUNCTIONALITY:
-- No extra Global variables needed!
-- Automatic light depending of opening and closing door
-- Time to enter - detecting another situations, like cleaning bathroom
doorID = 362;
lightID = 66;
-- time to enter, longer time will detect as another situation, like: cleaning
timeToEnter = 10;
local light = fibaro:getValue(lightID, 'value');
local door = fibaro:getValue(doorID, 'value');
local armed, lastArmed = fibaro:get(doorID, 'armed');
local trigger = fibaro:getSourceTrigger();
if (fibaro:countScenes()>1) then
  fibaro:debug('Kill second scene!');
  fibaro:abort();
end
if (trigger['type']=='property') then
  -- door trigger
  if (trigger['deviceID']==tostring(doorID)) then
    -- door opened
    if (door=='1') then
      fibaro:debug('Door opened.');
      if (armed=='0') then
        fibaro:call(lightID, 'turnOn');
        fibaro:call(doorID, 'setArmed', '1');
        fibaro:call(doorID, 'setArmed', '0');
        fibaro:debug('Light on!');
      end
    -- door closed
    elseif (door=='0') then
      fibaro:debug('Door closed.');
      if (armed=='1' or (os.time()-lastArmed)>=timeToEnter) then
        fibaro:call(lightID, 'turnOff');
        fibaro:debug('Light off, room empty!');
      else
        fibaro:debug('Someone inside!');
      end
    end
  -- light manual
  elseif (trigger['deviceID']==tostring(lightID) and (os.time()-lastArmed)>0) then
    -- light manual off
    if (light=='0') then
      if (door=='1') then
        -- when door are opened
      else
        -- when door are closed
      end
      fibaro:debug('Light manual off!');
    -- light manual on
    elseif (light=='1') then
      fibaro:debug('Light manual on, arming...');
    end
  end
end
задан 18 Май '15, 11:18
Eduard1000's gravatar image
Eduard1000
122
процент согласия: 0%
отредактирован 19 Май '15, 13:20
Nils_Bohr's gravatar image
Nils_Bohr
2.3k310
if (fibaro:countScenes()>1) then fibaro:debug('Kill second scene!'); fibaro:abort(); else --здесь Ваша программа
end
ссылка
отвечен 18 Май '15, 23:08
Gulayev's gravatar image
Gulayev
1.5k814
процент согласия: 10%
Извините! Мне надо было только ЭТУ строчку и процитироать, вместо всей сцены. Потому я и не могу разобраться - что может быть причиной запуска нескольких сцен? Я то запускаю лишь одну....
ссылка
отвечен 19 Май '15, 09:36
Eduard1000
122
В коде сцены присутсвует, например fibaro:call(lightID, 'turnOn') что будет приводить к запуску этой же сцены согласно %% properties 66 value
ссылка
отвечен 19 Май '15, 15:33
zodchij's gravatar image
zodchij
3112
процент согласия: 50%
Ваш ответ
toggle preview
Следить за этим вопросом
По почте:
По RSS:
Ответы
Ответы и комментарии
Основы размётки
  • *курсив* или _курсив_
  • **жирный** или __жирный__
×167
×37
×14
Задан: 18 Май '15, 11:18
Просмотров: 4,830 раз
Отредактирован: 19 Май '15, 15:33
powered by OSQA
