Добрый день! Есть следующая задача: Включать теплый пол на улице по будням в определенное время, если температура на улице в пределах -5...+2, и выключать через 2 часа. Создана такая сцена:
При этом сцена работает не так, как хочется: включается по несколько раз (приходят соответствующие PUSH), в центре сообщений постоянно висит ошибка: "Number of instances of scene has been reduced due to exceeding limit." Подскажите, что сделано не так? Прошивка 4.090. "Уличная температура": DS18B20, подключенный к Fibaro Universal Sensor. "Теплый пол": канал на FGS-221 |
Здравствуйте! Попробуйте преобразовать сцену в LUA и добавить такой блок:
einnews.comGarment Conveyors with the RFID wardrobe An automated garment conveyors systems is an innovative business solution which provides seal machines for the dry cleaners. It makes the laundry in an automated assembly system with ready to wear laundry. The automated wardrobe provides a full line of clothes in the correct form and handles various issues with efficient performance and minimal maintenance. The garment conveyor conveyors helps to meet the industry standard in a reliable and effective way. So enhance the productivity of your business by assuring profitability. Save time, money and space with garment conveyors The garment conveyor provides flexibility to the automated uniform system. The rotary of uniform fits every type of shape or uniform and fulfills your requirements. No one has authorized entry to hang the uniform. Yet , the access of doors and delivered uniform can only be operated with RFID technology or barcodes embedded card assigned to the authorized members. The automated garment conveyors will restock the clean uniform, and the number of uniforms of all size and type is easily configured through the smart track. The clients should be able to fulfill their laundry needs. The uniform items will probably be scanned and are available for immediate issue. How it works The staff and the members of the family will swipe their ID card and acquire the necessary garments from the automated uniform management system. The system is fully automatic with the intelligent positioning technology. Touch screen technology will be embedded in every door so see the exact amount of items available by swiping the ID card and selecting the easy on-screen options. Benefits and features of garment conveyors Following are the benefits of automated uniform system ᾿ It is a fully secured system so no unauthorized access will be able to hang uniform ᾿ The system is fully automatic with no extra slots ᾿ It is efficient, practical and reliable garment conveyor conveyors ᾿ Easy to use and configure the uniform operation room ᾿ The garments can easily be tracked trough the RFID software ᾿ Fully management of all the inventory ᾿ Works with personal and everything size of uniform ᾿ Could be operated with barcode tagged garments or RFID-embedded potato chips Save your time, save money and space with the efficient or automatic system. Read the detailed report on automated uniform management system. |
